First of all, Here is the beast:
I know, Chrome's gotta go. And it will with time, but that's not the top of the list, yet.
Let me start by saying that I have a bit of a learning curve to overcome with this. I'm not auto-ignorant, but I'm no home-garage master mechanic, either. I fit somewhere in between (probably closer to the lower spectrum). So I will need some "pretend I'm 6yrs old" type of instructions.
Basically, what is happening is that the truck stalls off idle. Whether it be sitting still in Neutral/Park or accelerating from a stop-light, it either hesitates or completely dies when I first press the go-pedal. Usually, if I feather it just right to get it moving, it'll run fine through the rest of the RPM range. It'll also sometimes completely stop exhibiting the issue once it has warmed up and been run for a while.
I had been told that this could potentially be caused by a bad distributor, or moisture getting to the connections. I went ahead and replaced the cap, rotor, wires, and plugs to no avail. There were also a lot of vacuum lines with busted connections, which was fixed by my mechanic. It seems to run quite rich, judging from the smell of things, but I have very limited (read:none) experience tuning carbs. No time like the present to learn, though.
I've searched through a few threads regarding similar issues, and have a couple ideas of what to check. First is another sneaky little vacuum leak. What is the best process to seek them out? Another process that seemed to work for someone was "advancing" the Distributor cap. What, exactly, should I do to attempt this? The third thing I've seen is that it might be one of many issues with the carb. Choke stuck, idle too low, AFR off, etc. Where do I start and what are my steps to take?
Any other suggestions are very welcome and appreciated. Just remember "pretend I'm 6yrs old". I've already put in the payment for my membership, because I know I'll be getting help here and it's only fair that I pitch in. Thanks in advance.
