I posted in the introductions and never got a response
so I thought I would find a place to introduce my self and seek some guidence.
So, I live in Northeast CO. I am looking to replace the axles in Big Blue and repair my t case. I've now been told 2 thing repeatedly. It could be the output shaft or the slip yoke. Both show wear, but I assume the slip yoke should wear first. Correct? Additionally, slip yoke eliminator (question below)? Also, I have found some 3/4 ton axles, if they're 4.11's I want them, they are out of a mid 80s sub. Would'nt they likely be 3.73s? What is an easy way to tell without opening them up? Thanks. The following is from my introduction with other questions.
"I don't know where I've been all this time, but I am sure glad to have found this site.
Well, it's time. My Big Blue needs some love and I've been out of the hardcore 4x4 world for a few years now and am in need of some guidence.
Big Blue is a 90 K5 that is almost all stock, except for new springs all around and some 33's under it. The reason I found this site is, I am looking for a new output shaft (np241c) if I remember correctly. Plus, I was wondering what the real life pros and cons of a slip yoke eliminator are? I am not ruling out a total change out of the tcase, but as always I must consider the cost.
My wife says I need to figure out what it will take to change out the axles to something stronger. Then I said, OK! What year(s) of 1 ton axles will swap in "easily"?
Thanks. Glad to be part of this."
so I thought I would find a place to introduce my self and seek some guidence.So, I live in Northeast CO. I am looking to replace the axles in Big Blue and repair my t case. I've now been told 2 thing repeatedly. It could be the output shaft or the slip yoke. Both show wear, but I assume the slip yoke should wear first. Correct? Additionally, slip yoke eliminator (question below)? Also, I have found some 3/4 ton axles, if they're 4.11's I want them, they are out of a mid 80s sub. Would'nt they likely be 3.73s? What is an easy way to tell without opening them up? Thanks. The following is from my introduction with other questions.
