New Tool, PS Pump tightener, no more crushed housing!
uglytruk
IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
I was changing the belts on my 6.2, and ran into the same prob I've had since I had a '67 283 back in 1978. How to tighten the PS pump without crushing it? Well, the solution wuz zo zimple, I can't believe I never tackled it before.
You'll need a welder and some scrap steel. Hopefully, the pix will explain all. Don't forget to notch the "tooth" to allow for the seam on the pump.
I used a lug wrench socket to receive the handle to be able to use the tool on different engines. Each one will have a different angle to clear obstructions up top... ENJOY...
looks like a lever to tension the belt? but this one doesn't apply leverage to the pump housing?? did I win??
heheh all my stuff has serpentine belts. OOOOHHHH
Laughing at my invention??? Well I never...
Oh boyyyyyy.
It just grabs the pump (bracket) on the non-damage side. You push the bar towards the tstat, and voila, no prybar dent on the soft pump. It works great!
I'll investigate posting a brief video. Can it be done right on/from the forum? Or do I have to link it?
As far as serpentine belts go, you're lucky to live in the next century. Me, I'm just getting used to locking steering column... :haha:
nice idea man. allthough ive found that i can put the curved end of a mini-crow bar on the frame rail the tip of the curved end under that same portion of the bracket. i just rock the bar towards the fender and it's all tensioned and stuff.
i do like your tool a lot though.
Very nice...I could have used something like that a few times. Nothing like the chevy mating call to make you want to tighten the belts! (very embarassing when wheeling with a bunch of jeep guys).
My power steering pump will thank you. I was hoping that my pump wasn't starving from any dents when tensioning.
Thanks for the idea.
