dirtwarrior17
Banned
all im gonna say is watch your step bro... could turn into a buch of bs on every post.
dirtwarrior17 said:all im gonna say is watch your step bro... could turn into a buch of bs on every post.
KidJethro said:You wanna know why I didn't order my gears and Detriot from you? Simple. Cause I can't frickin stand you. Stay the hell out of my posts you moron. You have nothing to say that I want to hear. I don't care about your opinions. You don't come into someones post who's proud of something, or bragging about something, and say that it sucks, or you have a better one or you coulda got it cheaper...etc It's rude. I cannot believe you havent mouthed off to the wrong person and gotten your ass beat for it. You agree? Piss off. Who cares if timmy agrees? You have no tact what so ever. Always opening your pie hole and spewing forth a constant stream of sh!t. I would think that Canmore would agree with me...and countless others. Good thing you live 2000 miles away from me. Stay there.![]()
KidJethro said:
This guys ego is unreal.....
TrcksR4ME said:I totally agree. I notice that the other vendors on the site do not act the way Tim does. I bought parts from him once and will not again because of things he posted in my posts, same reasons you noted above. People buy from him because he sells so cheap, but he is an a$$hat otherwise. Tim,![]()
__________________
'77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
http://www.krazyk5.com
http://community.webshots.com/user/trcksr4me
http://community.webshots.com/user/trcksr4me2
TrcksR4ME said:As a business you are good to deal with, as a person you can be an a$$. Imagine how much more business you would have if you could bite your tongue once and a while. Just because you can post a reply in a thread doesn't mean you should
And I would PM if I could and am frankly too lazy to email.
Well, if it's pretty darned snappy once it gets going maybe someone turned up the pump or even changed the injectors at one point, you'll have to find out. I do suspect something not completely stock if it pulls as well as you say and obviously has guages already.KidJethro said:It's a 12 valve and I'm definatley working on talking them down from $14k. I'm gonna go check it out alittle better today. Didn't really get a chance to crawl around under it and poke and prod at stuff.
That would be pretty cool if it is bombed a little. Back when I was shopping I drove a 98 12v with a turned up pump and injectors but with an NV4500. It was a lot of power once the turbo spooled up but it lagged bad...but with the auto in that truck you only have to deal with a sluggish turbo once.
THe more I thought about 14K isn't all THAT bad, especially if it is turned up a bit. If you like it I would go for it, and getting them to drop a little would be icing on the cake.
jac6695 said:Timmay, if you read his original post, and not someone else's response, then you would see that he is only showing off a truck he is trying to buy. He never asked for yours or any opinion at all, but once again, because you are the all knowing Timmay, you had to offer an opinion and try to show that you are SO much smarter then everyone else.
Looks like a nice truck to me. I am sure that you will enjoy it for a long time if you end up with it.![]()
rjfguitar said:Well, if it's pretty darned snappy once it gets going maybe someone turned up the pump or even changed the injectors at one point, you'll have to find out. I do suspect something not completely stock if it pulls as well as you say and obviously has guages already.That would be pretty cool if it is bombed a little.
77ChevyK10 said:down the road form me i found a 99' ram 2500 ex-cab longbed daully with the Cummins for $8,000
Andrew
Jonny-K5 said:personally i'd rather have a bone stock rig than one thats already been "bombed". you dont know how much the PO's have been throttling it. the more a motor is souped up and the more fuel it burns, the shorter its lifespan will be.
Dodge only offered a regular cab and quad cab from 1994 to 2002.tobad its not extended or crew cab
rjfguitar said:It depends. My dad was looking at an '02 dmax that was strait piped and had guages. Obviously the PO had a chip in it. Didn't bother me one bit. If I had to guess I would say if a truck is equipped with guages and is setup for more power, the PO wanted to do it right instead of just sticking a chip in or turning the pump up and not caring what is going on with it. Also, with 140K on that '98 and it having a chance of being turned up it probably has a newer tranny in it.
If you were looking at two identical blazers for the same price but one with a stock 350 and one with a built 406...which would you take?![]()
even if its built properly it still wont last as long as a stock engine. of course thats assuming that the PO was actually using the added power, which is basically a given. just like if you putt around in with a stock engine, it will provide many more trouble free miles than if you floored it all the time.If I had to guess I would say if a truck is equipped with guages and is setup for more power, the PO wanted to do it right instead of just sticking a chip in or turning the pump up and not caring what is going on with it.
or has a fragged tranny thats on the brink of needing rebuilt.Also, with 140K on that '98 and it having a chance of being turned up it probably has a newer tranny in it.
