I just bought this 85 GMC k1500. It has 10 bolts front/rear. I am putting in a dana 44 and a 14 bolt with rear disc. My question is, The 44 has 2-3/4" axle tubes and the 10 bolt has 3" tubes. Can you use the 10 bolt upper front plates and ubolts or do I need to change to new upper plates when I get my new u-bolts.
I am trying to determine if I should order the 73-76 kit or the 77-87 lift kit.
