New Trailer
kgblazerfive
keymaster
Hooper, Utah 84315
Got a new trailer to match my new tow rig so now the Burb has transportation to Moab and other surrounding areas.
The axle are actually moveable :rolleyes: not sure if that is good or bad they are only held in with four bolts might have to do some welding to change that. The bed needs a couple of boards replaced. Might change the wood over the wheels to steel give the tires a little bit more room. May even dove tail it, have to build a new set of ramps the two that came with it probably weigh 200# each.
Nice setup! How long is it? Looks like you could fit two rigs on there.
