New Tuff Country 3” lift.
Looks good! Did it give you 3” as advertised? Did you do the brake lines as well?
No the break lines were not changed, the only other thing the mechanic did was put a plate on the frame by the power steering pump, the frame was not cracked yet but he said it is a weak spot. This lift actually dropped the height of the truck, they also changed the steering where necessary. I do not rock crawl this truck it mostly sees rough pasture driving getting from two track pasture roads to areas of chalk, pretty rough at times.1CE1FB32-97E8-48B9-AFD4-0D43CC0DC7A2.jpeg
