---new Vendor Poly Performance---
bigge
Registered Member
central coast, ca
Just thought I would put a post with a little more about us, and what we do.
We are Poly Performance, located on the Central Coast Of California.
We specialize in Weld on Fabrication Brackets, Coil Over Shocks, as well as pretty much anything else you could need for your rig.
Below are a few samples of the products we offer.
These are our 3" Radius Axle Link Brackets, Available in 0, 5, 10, and 25 degree offset.
This is our New Universal Rear Axle Truss, Which has the upper link mounts incorporated into it.
Fits most differentials, Dana 35, 44, 60, Ford 8.8", 9.0" & Chevy 14 bolt housings.
Here are some eye candy pics of the types of shocks that we stock
Fox 2.0 Remote Reservoir Coil Over Shock
Fox 2.0 Air Bump Stops, We manufacture the mounting cans in house also.
Sway-A-Way 2.0 Remote Reservoir Coil Over Shock.
WE HAVE A LOT MORE MERCHANDISE IN STOCK, AND AVAILABLE THAN I CAN FIT IN THIS POST
IF YOU HAVE ANY QUESTIONS GIVE US A CALL 805-783-2060, CHECK OUT OUR WEBSITE WWW.POLYPERFORMANCE.COM, OR SHOOT ME A MESSAGE.
cool... have a little shopping list of stuff I want from you guys...
I put this post up just as a feeler as to what all of you CK5 readers would be interested in before I started any specials.
If there is something that anybody is looking for, PM me, and I will see what kind of a deal I can work for you.
The channel that goes over the axle tube is a set size. I would think that you could open it up a little to fit around a 4" axle tube, the only fitment issue I can see is if the width of your carrier is too wide for the truss too fit around it.
What would be considered to wide? I'm running a 70HD too, and was wondering to same thing.
