DrkZide
Loading...
So I took the truck in to Brakes Plus to have the front pads changed out since they started to squeal and I wanted to put off buying a High Lift until after Christmas. They called me about some of the extra issues they found...
- The passenger rear brake forward brake shoe had come apart and the backing has been pressing against the drum, scoring the drum.
- The passenger rear wheel cylinder is over extended and has lost the plungers
- The front rotors are below minimum specification and need to be replaced (which apparently you need to remove the hubs and press out the studs in order to remove)
- The 4WD does not engage, the forward driveshaft spins but not the wheel.
So all in all, if I get this right. I need two wheel cylinders, two set of pads and shoes, two sets of rotors, a brake drum, a hub kit(?) and whatever the hell is broken on the 4WD system.
Can some of those parts be bought used? Do you guys suggest buying new all the way around? Where can I find out how to re-do the front hubs (Haynes manual maybe?)?
Any help would be GREATLY appreciated.
P.S. Brakes Plus quoted me almost a grand to repair just the brakes, looks like it's mostly labor though.
http://sphotos.ak.fbcdn.net/hphotos..._473098824341_737969341_5782972_5966821_n.jpg
. and never had a problem with squeeks again.
