wingman
Registered Member
Hello,
My name is Mike. I have a '70 Blazer that my Grandfather bought new. It's got the 350, wide ratio 4spd. It's pretty clean. Gramps took good care of her. Plans include motor upgrade. The last guy that did a motor overhaul took advantage and gave him a low hp 350 and kept the original block
. Also need to do upholstery. The Nevada sun did a number on the seats. I've already put a 4" lift and 35's on it. Thanks for reading.
Countless road trips and memories tied up in this truck.
. The axle IS under the springs. Anyway, you can see the stance in the first pic. 2" block will fix it.
