Hey guys. Here goes my first post. I do alot of research on the site and have gotten alot of technical knowledge. So i know you guys are going to have some mixed reviews about my K5. I get alot of weird looks from 1geners about it. So have at it.
So i've had alot of time to save up for a whole new setup as the blaze needs it. So i'll give you guys some history of it. I bought it in 2007 at a dealership/it was parked in the back and one of my friends knew I wanted one so he pointed it out. I liked it because it was unique and the craftsmenship was great. I ran into a previous owner sometime later and he said that some guy chopped it in Cali years ago. Someone spent some time cause the welds on the fenders/frame are great. I'm not sure how the quarter panels are, I guess i'll find out when I do a repaint. Lets hope for the best.
For running gear it has a vette 327/4speed/205. Second day i had it i snapped the rear output shaft off the dana 20 so I found a 205 and threw it in. It has stock axles with 4in lift blocks in the back and i'm not sure of the springs in front.
Ive had alot of time to save for a whole new drivetrain/suspension. Here are my ideas so far. Has 35's on it currently but they only sit at 33 1/2. I want to run 38's hopefully. I might cut the rear out of the lower quarters for more tire space. I know i have the room in the front with the fenders modified already. Bumper is getting replaced by Blazen Offroad tube/winch. Might run up to Blazen to have a custom rear bumper made with tire carrier.
1 tons
ORD Shackle flip
DIY4X FGB52's
ORD Tuff Country springs w/zero rates
ORD Crossover steering or High steer
Carb'd LQ4
Roll Cage
Possibly an automatic but the rear drive shaft might be too short. Any thoughts?
About the crossover steering/high steer. I haven't found any steering dampers with the high steer and i'm not sure if I even need it.
The pos soft top has gotten scrapped and hope to find a hard top to take to the fiberglass shop.
Any suggestions you guys might have would be greatly appreciated.
SGT Lynch, deployed in Iraq
1 tons
ORD Shackle flip
DIY4X FGB52's
Carb'd LQ4
Roll Cage
