Newbie 203 question
1-tonmudder
In a junkyard somewhere
While I'm not really a newbie,this is probably a newbie question.I was tearing down a 203 for the rangebox the other day and found this in the tailsection of it.
Is that the parttime kit for a 203,if so is that all of it or is there more.I have tore down at least a dozen 203's and have never came across this particular part.Dads 77 is needing a parttime kit put in it so will it matter that it came out of a Ford 203???
looks like a Doug Nash or Mile marker part time shaft. the bottom gear is for the oil pump and the top is for the speedo. And from what I have read the ford and the gm are a bit different. Maybe contact mile marker for the info on that 1800 8868647, they were pretty helpful when I talked to them about the same shaft. They sent me all the install info too.
I'm in Chattanooga. I've got a wrecked blazer with a good NP-203 mated to a TH-350. It has the part time kit. Let me know if you want to buy it. I think it has the Mile Marker kit.
