Shot it twice just for kicks, but it looks like they both came out really close.. So I'm guessing a 6° shim (?) would get me in the ballpark?
Also, I'm a little concerned that my rear driveshaft is a little too short? I've got roughly 4 inches of lift in the back with the super shackles and zero rates.. Plus the axle being relocated towards the rear an inch to compensate for the flip.. Dont want to jump this thing or do something stupid and have it pop out
I istalled the ORD 4" shackle flip on the rear of my 86.
Required a 6 degree shim to point the pinion back down.
Also lowered the transfer case 3/4" using steel strips and the old front shackles.
Got my pinion and tcase output angles within .8 degrees of each other.
Operating angles (driveshaft angle minus pinion or output angle) of each joint are within .8 degree too.
After that, i measured from the output spline of the tcase to the ear of the pinion yoke.
Called Tom Woods Driveshaft and had them build me a new standard 2 ujoint Cardan driveshaft.
Had i wanted a Double Cardan at the tcase, i'd have left the pinion pointing up at the tcase output like it was after the shackle flip.
One thing about a double Cardan or cv driveshaft; they are heavy and put a lot of load on the stock bushing in the output housing of the np208.
It is recommended that a slip yoke eliminator kit be installed.
So i decided to just stick with a 2 ujoint driveshaft but had a new one made to proper length.
Knowing that even if i set the pinion and tcase angles within 1 degree parallel of each other, the 13 and 14 degree operating angles of the ujoints will shorten their lives to about 20%.
100% being 8 hours a day, 5 days a week, for 5 years.
I can live with 20%.
But you should decide what you are going to do about those angles, and which type of driveshaft you want to run, before you have a new shaft made.
Have a look at Tom Woods Driveshaft site.
Lot of info there.
There is also one called Bella something.
Lots of info there.
Now, i still ended up with a 20 degree slope on my driveshaft.
That is way beyond normal.
Never fully be smooth.
Thats why a lot of guys go with a cv shaft, slip yoke eliminator or not.
Cv shaft will always be smoother.
Lifting trucks is a compromise.
Those shocks are too short.
Send them back.
You wont be happy.
