Just moved to AZ and loving the off road options. Sold my motorcycle to buy a off road vehicle.....
Looked at this: 1989, not rusty (so-cal) 173k miles on original motor, rebuilt trans a year ago. replaced np208 with NP241 transfer at some point in the past. It's been in the family from new (grandfather to father to son for what that's worth). Front drive shaft removed. Apparently 4Hi works but won't shift to neutral. He mentioned might have been an issue with the changeover/adaptation? Broken rear shock mount. 3.73 gear. 3 inch body lift. Steering is loose. Hedman headers and dual exhaust (sounds good for what that's worth)
Runs good. In good shape. one decent size dent and the paint is shot. Needs 3 new tires. One is new because of blowout. The interior is not great.
I will be using for off roading in the AZ desert (rocks not dunes). Not a daily driver, but wouldn't mind cruising around. I don't care what it looks like. I will start of on pretty tame trails but who knows from there.
Here's what I think I know from the site: body lifts sucks, broken shock mount is not a deal breaker. Tires are expensive. Transfer cases are cheap. 3.73 won't last long on trails, but at least I can get decent mileage if I want to drive on road. TBI is better than carb?
Questions: What's the likely and or worst case issue with the transfer case?
Can a newb replace the transfer case?
Is 173k miles getting to rebuild time? I don't think this was off road much/abused.
Does this sound like a reasonable use of $2300? I'd really like a 73-75 for the full removable top, but I'm thinking a 89 would be a better bet for a very novice mechanic. Is that a fair assumption?
Any feedback is appreciated.
Sounds like it may have the cat removes and running duels. If you don't need to have smog inspections where you are. then not a problem.. Calif state law says the seller is to prove a smog cert.
