embelishd
Newbie
I just picked up a '76 K5 Pickup for winter use and had a couple questions. (keep in mind I'm not mechanically inclined)
First, I was wondering what is the metal "button" on the floor just right of the e-brake?
When I first start her up she tends to die when I put it in drive...usually does better putting in reverse and backing up a little ways then going forward....any idea why? Carb need cleaned? If so is it better to have a professional do it or is SeaFoam good enough?
Last question (for now).....I park the truck on the road in front of my house and its a very slight incline....when I first parked her, she started rolling back....eventually I figured out that it had something to do with the shifter on the column (automatic trans).....When I put it in park I have to wiggle it a little for it to grab. Is this a big problem or an easy fix?
