k5 krawler 50
Hey guys, I've started putting together my 241 doubler and when the 241 was dropped off, the guy told me it was 27 spline so i could bolt it up to my th350 no problems.. well after getting my block off plates already welded to the case housing i thought to my self, maybe i should now check to see if the input is infact 27 spline, well guess what.. its the 32 spline model, i guess thats what i get for not checking free gear
. Anyways, i realized i could try and track down a 27 spline input, but i figured my tranny could use an upgrade anyway, so i've been somewhat researching the th400's a little bit. However, i havent found too much info about an adapter that connects the th400 to the 241. Would any of you know any part numbers or where i might be able to find an adapter for this set up? I checked with advanced adapters and they list one on their site for somewhere around 500 bucks
. So any help for my newbie question would be awesome, and also any links to some good th400 readings would be awesome too. Thanks.
Cory
. So any help for my newbie question would be awesome, and also any links to some good th400 readings would be awesome too. Thanks.Cory
