Newbie here and I picked up an 87 K5 with 4" lift, rebuilt 350, rebuilt 700r, 31" BFG's, runs great.
There was a different tailgate put on the blazer and it has an elec window and the old one did not. So there are a green wire, a single wire with plug, and a dble wire with 2 prongs on it. I put the green to the neg on a battery and touched a pos on each of the 3 other wires and nothing happened. Window is down and I need to get it up, what am I doing wrong?
Blazer has 4" lift with an additonal 2" lift in the front. I need at least front shocks since there isn't any at all! I see on feebay that there is a set of 4 Highjackers for like $33 each and I can choose 4" or 6" lift for a set. But don't I need a 4" on the rears and 6" on the fronts? Any local parts stores have similar shocks at the same prices?? We have Autozone,Carquest, and Checker.
Driver side valve cover has a rubber gromet and there is a taped off hose by it that runs to the back of the carb, do I just stick it in or is there something that goes there? Wonder why the hose is taped off?
Would like to buy a rear seat in Las Vegas area. Thanks.
