Newbie....
hammermachine
The East Coast Texas
:haha: Hi, I just bought a new old ride a 1983 Blazer that I plan to turn into a serious off roader. Any Ideas as to what to start with for the build up?
6" and 39's. As soon as you put 35's on, you'll wish you went bigger. After that, 3/4 or 1-ton axles.
We like 'em low with as big a tire as you are willing to cut the sheet metal to make fit.
Personally, I'd go with 2-2.5 inches and 35's...or 4 inches and 39's or 42's, but 4 inches and 35's is a good set up for beginners that won't be too hard of a modification i.e less cutting on fenders, decent clearance, looks, lower center of gravity, plus it keeps costs down over a 6 inch lift. . Plus 35's is about the limit for 10 bolts....
X2:waytogo:
dont even think of doing anything unless its Dana 60/14 bolt, 42 irock w/ rear shackle flip/ x over steering and hydro assist.. hehe just kidding..
i would go with a 6" lift, do a shackle flip in the rear w/ a 2" block, then u can pick up some front used springs for about 150 on here, get the steering brace for your frame from ord, and get some 35-37" tires. My home made shackle flip, 6" front spring, and steering brace with 37" tires cost me a total of..500bucks and i can use the stock driveshafts too. ad in another 500total if you want a dana 44 front w/ 14bolt rear and you'll really be set.
X3--And with 35's you can still get away with stock gears.
I don't think so, same strength and much much cheaper/easier to find parts for. Used parts that it. Dana 44's beat out the 10 bolt when it comes to availabilty of lockers/limited slips. But that's about it. Oh and if you have auto hubs, the first mod should be to get rid of them.
no real advantage over d44 but it does have 8lug so thats nice to have a 14bolt rear and same 8lugs in the front.
Ummm...10 bolts came in 3/4t trucks from 80 and up...not all d44's are 8 lugs.
