Newer chevy wheel adapters
R
RIPPEDK5
Guest
Any one know where i can find wheel adapter that fit 6x5.5 to 6x5.5 that are wider then 2" (thicker)?
Did a quick search for (6x5.5 to 6x5.5 wheel adapter "3 wide") got a number of hits this is just one. clicky
That would be called a wheel spacer and not an adapter if the bolt circle is the same, unless someone is calling it an adapter because there are two sets of holes and the "adapter" bolts to the axle with one set of holes while the wheel bolts to a different set of studs.
Glad you found that site... I couldnt find it... But Those look like the ticket.. I have 2" pacers now which have been very strong. How do you think these will hold up to everyday use and abuse?
i have had wheel spacers on my rear axle for few years now no problems.
4-5k lbs of weight and offroading and daily driver use along with plowing snow.
