Newer Style np205 and adapter From a th400
LoggieStyle
Tujunga, CA
yup, I need round bolt pattern np205 and adapter from behind a th400. If anyone has either one for sale, let me know.
Thanks,
Logan
i have an adapter to go from th400 to no. 8 (or oval) bolt pattern np205, no shifter or linkage, used it.
i have a pic of it if you want i can send it to you.
I have an early '80's NP205 (hourglass bolt pattern though) with a TH400 adapter. It is good-to-go. The only reason I am not using it is because I acquired a late model NP205 to go behind my NV4500. PM me if you are interested.
Nick
I'll keep you in mind but the reason I need a newer np205 is because I am trying to mate it to a 4l80 and I was told that I need the long 32 spline input that the newer 205s have. I don't really want to buy a t-case and then have to spend another $200 to replace the input shaft unless all else fails.
Thanks,
Logan
