Next step?
84bigblue
Tucson
Trying to decide whaty next step in my build should be. up untill now i havnt had much of a choice as its been primarily getting her running good and fixing what i brake on my test trail. as of now the engine is running great im in love with the holley ta and seems to be exactly what i wanted. i think iv finally got the drive train all fixed up other then a few minor things and a good test in 4x4. (blew up the t case and had to get the drive shafts extended). as of now i plan on doing a few small things like hooking up a cb radio and such. but here are a few of the bigger things id like to do
-diy4x dash with new guages and fix up electrical from the previous owner
-ord front leafs for 6inch lift. it currently has a rough country 6 inch lift but looking for a smoother ride
-build bumpers to replace the stock ones both rear and front.
I cant decide which should take priority over the others so any suggestions or suggestions on something else i should look into or do instead would be helpful thanks in advance
Working with what you have listed I would do ORD springs first as that is ride related and easy to do in a day or less. Then I would do the Dash and fix electrical from previous owner while installing the CB radio. Then I would move to bumpers.
This is just going off the list you wrote.
Thinking maybe I should not say anything when I got a million things to do to my truck still and need to figure out my order to.
Thats kinda how i was leaning as well, the only exeption is it would be mice to get new guages in as my factory ones ether just flat out dont work or read very inacuretly and would be nice to get a tach guage in there. some other things i would love to do is cross over steering with hydro assist but want to wait untill i can find 1 ton axles for the truck. thanks for the response :burnout:
