Has anyone found a formula for calculating volume of gas given a temperature and pressure? I want to figure out how many times a 22 cubic foot nitrogen tank, at 2,000psi, will fill four 35x12.50xr16 tires from 12psi to 30psi.
I might be getting too technical here, but I just want to know how many times I can use this tank to fill my tires before dropping $180 on a tank and fill or $400 for a Viair 10007 continuous duty compressor.
Skunked linked you to the proper chart though. About 24 tires, if you use 20PSI as the increase on a 20lb Co2 tank, the most commonly found on Craigslist.
