bigbadchev84
I got a 72 blazer that i installed a new summit wiring harness into almost a year ago, everything has worked great, I just recently swapped it from a 4speed to an auto, changed the pedals and column too, this is where i think i may have lost them.
Everything works except the brake lights, hazards, turn and tail. I just swapped out the turn signal witch today thinking that was my problem since i got power to the brake light switch at the pedal. I have also tried a jumper wire to bypass the switch, no go. I have 1157 bulbs in there now and they are in good condition. HELP!!!
