sope
See if anybody's got any theories or if mine is right. My pedal goes to the floor. This only happens when wheeling, when my wheels are cranked hard and my usually when my truck is pointed down hill. Once I'm out of the obsticle brakes are fine. I'm always jamed against something when this happens so it hasn't become a safety issue yet.
I'm thinking that mabe by tolerences are too tight between my ground calipers and my rims and the calipers are being pushed towards the cantre of the truck when the reims flex a little. The only thing that kind of wrechs this theory is that they won't pump up.
Anybody got any other theories, experiences or opinions?
My brake specs are front one ton calipers (ground), rear 13" brakes from an 3/4 ton ff 14 bolt,the rest is all factory 1/2 ton. Brakes work great other than this and after this happens the pedal is solid (no air).
That sounds very likely since I have braded lines thay could pull the calliper . I will check that and give an update.
I didn't think anything of it because its right at the end of my turning ability but I have hydro assist and can see how the ram would over power the piston in the brakes. guess the dual shocks are coming off now. they didn't hit when I had a 44 under the truck.
