Not that it isnt happening but brake fluid dosent just dissapear. Have look where it bolts up the firewall on the inside of the cab,a bad master can leak out the end of the bore and run down under yorur carpets and floor covering. If its a wheel cylinder it should be low in only one side of the MC if its a dual type. Theres gotta be traces somewhere. remember its water solluable moreless so a leak underside may be gotting washed away if your in rain or snow country.
