No brakes
timamybrown
Registered Member
coon rapids Mn
I have 92 2500 chevy 4x4 put new calipers on front and bleed them very well.still no front brakes the pedal goes to floor and only the back brakes lock up. HELP:1zhelp:
Sounds like a bad master.
How are the rears locking with the pedal at the floor?
The master is setup with 2 different reservoirs, one for front, one for back.....so if you don't have a massive front leak somewhere, its time for a new master.
Also, it is possible to bleed the new master like a standard style master....but to get a perfect bleed, it WILL need to be connected to a full diagnostic system to put the ABS in bleed mode. Most shops do not understand this.....
Got it fixed the back brakes were all the way down to the steel put new back brakes on and now it work great. the pedal came back and everything. thanks anyway.
