dwnhiller93
Registered Member
The only thing that comes out of my vents is hot air when I have it set to cold air. Even during the winter, I would turn the nob all the way over to cold, and it wouldn't change the temperature coming out of the vents at all. Now with summer, I want to recharge my A/C, but want to fix this problem first. I am thinking it is a vacuum leak? This is happening on an 87 blazer, 350 tbi.
You also might need to unfacin(sp?) the threaded rod on top of the box. You should be able to move that back and forth to move the door. I actually think there are two doors in there.
