fidelity101
Okay I'm thoroughly stumped on this one:
It is an 87 TBI 3/4 suburban 350
I have a no crank and no power in my accy and key on position.
No fuses are blown in the fuse panel, things like the horn and power windows do not work.
I have 12.3v going to the both B+ locations on the ignition switch but only 1v coming out at the accy/on position when I turn the key, Makes me think that it is an ign switch, so I replace it - still nothing.
starter gets 12.3V, junction block gets 12.3v, I cleaned the grounds behind the dash, core support, alternator bracket (they weren't rusty or anything either) just to be safe.
I had the starter tested at advance auto and it passed, the fuseable links at the starter and alternator were good, i was able to tug on them pretty good.
I do hear the fuel pump run with the key on position.
I'm clueless.
I'm clueless.
