Yes the auto trans neutral/reverse light switch, is on top of the steering column near the firewall. The switch is designed to only allow the engine to crank when in park, or neutral. The switch is kinda horse shoe shaped and just clips into the column. Because of where it is located it can hard to get it installed correctly. The switch it self has a small amount of adjustment, to fine tune once installed. Should be 2 purple 12ga wires plugged into the switch, sometimes one is yellow, depends on year and trans. If you unplug the connector with purple wires, one of them should have power when cranking. If you have power on one of the wires then chances are the switch is bad, installed poorly, or adjusted poorly. You can jumper the plug with purple wires and see it the truck will start, caution with the wires jumper-ed, it can and will start in gear.
