roughstockcowboy4
Registered Member
i have a 1986 blazer and i was driving today and stopped to load some stuff up and when i went to start the truck back up it wouldnt start. i tried ether to see if it was a fuel or fire problem and it tried to hit a couple of times but then wouldnt hit at all, pulled off the fuel line and checked for flow by cranking the key over and fuel was good. It seems i have no fire, i tried to do the old screwdriver in the plugwire trick and couldnt get fire, then i tried taking the plug out and grounding it while cranking, nothing. my first impression was the coil was bad as this just happened in my other truck so i changed it with no luck. i am going tomorrow to pick up a new distributpr cap and rotor button. i also checked the ign fuse and it was good, and i have a little over 11 volts to the coil. any ideas on what else this could be? I am stumped
and not very experienced. Any help is appreciated
. so I'm not sure which one of those it was but it fixed it. My new problem is that i found out the rear output of my t-case is leaking. Is that a hard fix or relatively simple?
