I agree 100%. Offroad anything goes to make your vehicle perform the best it can. Its just you and your rig, But when driving on the street you must think of the other drivers not just if your rig can flex going over speed bumps.
bownut said:The only reason I hadn't pulled it yet is because I occasionally will pull a trailer behind it. Do any of you also tow anything and have you seen any handling issues or reason why I shouldn't sh*t can it?
sub602 said:Especially if its a lifted truck. Not having a sway bar will not allow you to turn as fast or cause you to roll over due to too much body roll which could cause injuries to you and maybe someone else. When your driving on the street you have to think of safety over capabilties. You dont need to flex on the street. Not trying to be a buzz kill. Just trying to keep everyone safe.
JEBSR said:I can, but it wouldn't be until next week when I get home. A quick description of how it hooks up is... The disconnect bolts to the spring plates where the sway bar used to bolt. Then the sway bar goes into the other end of the disconnect and is held in with a pin. When going off road just pull the pin and raise the bar up to the frame where there is a 90* bracket mounted for retaining purposes. Just put the removed pin through the retaining bracket and your set. If your not comfortable with making some, ORD sells them.
http://offroaddesign.com/catalog/swaybarkit.htm
SUB602 said:I guess i am asking for it, but running a DD without a sway bar is very dangerous. What i havent seen on this tread is panic stopping or swerving to miss something or someone. When it comes to turning if you had to swerve to lets say not hit a child crossing the street the truck will continue to go in the opposite direction of the turn due to momentum. Especially if its a lifted truck. Not having a sway bar will not allow you to turn as fast or cause you to roll over due to too much body roll which could cause injuries to you and maybe someone else. When your driving on the street you have to think of safety over capabilties. You dont need to flex on the street. Not trying to be a buzz kill. Just trying to keep everyone safe.
Muddytazz said:When i had my suburban, it was lifted 6" suspension and 2" body lift. I had NO front sway bar and I pulled a 10K trailer with it all the time. Never ever did I get any body roll or feel like I was unsafe in any way.
