here's the short story bought sub with blown 350. replaced with 366 big block. all sensors from 350- installed on bb and kept tbi with the 700r4. wasn't getting fuel to tb. replaced the fuel pump relay, fuel pump and filter. still no fuel double checked that all connections were made for grounds and sensors. will fire if i put fuel in tb. any ideas as to possible cause? i fear i'm going to have to start looking for wiring gremlins. thanks.
ps im a newb to forum really enjoy the format
usually there is a wire that goes from the j block to the alternator w fusible link. for some reason this wiring harness didn't have one. wierd i know and believe me i dug around and pulled wire out of the casings to come to this conclusion. the wire in the harness that went to the alt came from where the harness goes into the cab and had no juice to it. then there was a wire that came back out from the cab to the jblock that did have power. so i made a 12 gauge wire that went from j block to alternator and everything works. now i need to figure out if i need to put a fusible link on it or if the link on the j block is good enough.
