As the title says I have no gauges, MOST of the cluster lights work however. (motor is an all-stock 350)
I have done some light troubleshooting and have found I do have 12 volts on the "gauges" fuse, however the 3 pink 12v supply wires in the 18-pin cluster harness have no power. I tried to follow the pink wires back but it is buried in harness wrap, but before I unwrap everything I thought I'd check here first if there is a known failure point for this.
One more side question, on a gauge dash where does the alt sensing wire usually go? It had a newer alternator plug in it when I got it and only had a wire going to the junction. I have an aftermarket alternator harness with a built in resistor and currently have it hooked up to one of the blank "ign" spots in the fuse. I bought a Pico fuse block tap but it doesn't fit. (anybody know a good source for one?)
