No Headlights, Turn Signal, Oil Pressure, And Beeper...
beastofablaze
CA
I Hooked Up My Battery Wrong And Got A Pretty Good Fireworks Show From The Terminal And Now I Have No Headlights, Turn Signal, Oil Pressure (gauge), Or Beeper When The Key Is In The Ignition And The Door Is Open..... No Blown Fuses. What Should I Check?
Fusible link coming off the starter to the terminal on the firewall. All the wires at that terminal should have 12V IIRC.
well the ecm should be ok because i have turn signals front and rear after i pulled the solenoid and soldered up the short stud to keep it from flopping around but i still have no oil pressure gauge or headlights... I am going to get a direct oil pressure unit and a T fitting to run stock and aftermarket oil pressure gauges but i NEED headlights... what else is there? all the wires look good. Is there a switch or fuse i'm forgetting?
