sandypants
i have an 89 k5. i recently upgraded to 8 lug 10 bolt and a 14sf bolt in the rear as well as adding a 6 in lift and 35's. now once in a whle i get a wobble in the front tires. they both wobble back and forth and keep getting more violent until i slow down or stop then im usually good to go and they dont do it again. usually only happens when i first start driving. also i notice the pitman arm was slidding off so i pushed it back up and tightened it. seems to happen a little less often. nothin is bent so im not sure. maybe pitman arm has something to do with it? thanx
