hawaiianblue78
Registered Member
Hi CK5 gang, long time lurker but hoping this post can help me solve a riddle on my new 1978 K5.
None of the gauges worked when I got the truck, and the only time they ever did was when I once had power to the pink wires on the seat belt buzzer and pink wires to the cluster plug. It must have been a fluke.
Currently, I have power through all fuses and they all test good. Thinking it was the ignition switch I dropped the column and replaced that and still no power to the +12v pink wires on the cluster plug or seat belt buzzer pink wires.
The wiring diagram I have looked at 100 times and it keeps referring to splice 39 as a pink wire junction where it seems like the cluster plug gets its +12v, but I can't make heads or tails of it and a few of the wiring diagrams that I've found online don't match up color wise even though they are the correct year.
Now that I'm about to install the motor and have rebuilt the cluster and even installed a new printed circuit (thought it was that also), can anyone tell me where the junction or spot that the cluster plug gets its power from?
