No power to guages and 2 other problems
Canadianbuilder
Thunder Bay Ontario Canada
I am just finishing up my 89 Suburban which I built from the ground up and I have a few minor problems.
The main problem I have is my factory temperature and oil pressure guages don`t work.The voltmeter works fine and I think the fuel guage is working but it is hard to be sure because there is only about 4 gallons of fuel in it.I have checked the fusebox with a testlight and at the fuse marked guages there is no power at either side of the fuse.Any ideas why there isn`t any power to that particular terminal?
The rest of the fusebox has power except for the fuse labeled crnk at the bottom of the panel.I honestly don`t know what that fuse is for:o .
The other 2 problems I have are the heater fan doesn`t work and the engine idle is way to high.I think I can figure the last 2 out although any help would be appreciated.The biggest head scratcher though is why the guage terminal in the fuse box is dead.Thanks.
