no responses...please delete!!!!
carolinafan4life63
south carolina
does anyone have the gm part numbers for the two small plastic bearings in the steering column? or for a tilt steering rebuild kit from gm that includes these bearings? also if anyone has an exploded diagram of the actuator assy. or rack assy. not sure what the correct name is :confused: the truck is an 83 with tilt steering with the dimmer switch on the floorboard!! a buddy asked me to fix his because his rack / actuator assy was broken ....he got an assy from the junkyard...but i seem to remember a spring that holds these pieces in and also activates the rod that locks the steering wheel......gt most of the stuff to put it back together ..but his bearings are shot (the plastic race is broken allowing the ball bearings to fall out...thanks
