No spark,,,,,again!!!
snowdriver
oregon
1990 completely stock 5.7 tbi,last time this happened I had to replace the ignition control module,and that solved it,now about a 1000 miles later I got no spark again,any ideas or give me a direction to go,,,
if it wasn't an acdelco one try another module for a start....
I may have just cured my same issue with a bad ground wire I found behind the dizzy
It was a module from car quest ,not a ac deco part,and I am looking at all the wires pretty carefully
Did you put a thin film of heat sink compound under the new module when you changed it?
It needs that to keep it from burning up.
