I finished installing my harness from PSI for my ly6 swap and have no spark at the plugs and, when testing with a noid light, I have nothing at the injectors. I have checked the power to the harness and have 12+ volts when ignition is on but it goes to 9-10 volts when cranking. I believe I have everything grounded properly and i have 58 psi at the fuel rail. so what else should I check before I send the PCM back to be checked out?
