No spark, have done some things, what to try next
aandpman
Austin, Texas
88 K5 TBI
Yesterday morning, she started up fine, but we got 1 mi from the house and she died out in waiting at a red light. I won't go into the turmoil that ensued...
Here's what I've done/determined so far...
** Distributor was replaced 2 years ago**
Wires & plugs were replaced ~ yr ago
Have had occasional stumbling at startup for a long time now, like it was running on < all 8, then it would just clear up.
I have determined, using a spark tester:
No spark at plugs
No spark at coil
I have +12 at the input to the coil
I have +12 at the pump plug near the tank
Continuity thru the pump to ground.
Fuel pump operating when I put +12 to the test lead from the relay
Replaced ignition module - no change
Replaced coil - No change
Replaced Fuel Pump relay - No change
Replaced Oil Pressure Switch (below the distributor) no change
Cap looks good, rotor looks good
Disconnected the 4 terminal distributor connector, still no spark at the coil.
Checked SES codes using the paper-clip method, only getting code 12 over and over.
Lights all work.
The trigger magnet sucks my screwdriver to itself, so I don't much suspect that it's gone bad. I wanted to avoid throwing another distributor at it just so I can see if the pickup is bad.
:dunno: That's it so far, and I'm stumped. What am I missing?
Ironically, this happened the DAY AFTER I ordered some gears and stuff to get my front end to 3.73's to match the rear.
Go figure - maybe she read my mind and doesn't want me tinkering with her front end :haha:
Check those connectors and wires going from the coil to the distributor. I had issues with mine that left it stuck at the parents house back in Indiana for two years.
Turned out to be a bad connector to coil problem, heck even Autozone sells a replacement pigtail wire for it. :-/
ECM fuse?..pick up coil?..ohm meter can test that..
Also a rotor and or cap can "look good" but still have a carbon track that'll send the spark to ground rather than fire the plugs,and those years seem to be more prone to that than the older "big cap" HEI's were..
:waytogo:Well - it turned out to be the pickup coil...
Pulled the dizzy and put a new pickup coil in. now she's back in the driveway....:pimp:
Thanks for all the suggestions, y'all....:thumb:
