ripperoo187
1989 k5 blazer 350 tbi
I was driving down the road and my blazer's engine died. I get towed, no spark, engine turns over fine, tbi is spraying fuel and I can hear the fuel pump pressurizing. I checked the fuses under the drivers side dash they are all good via test light. The ignition coil is new, tps sensor is new, IAC is new. Throttle body is a refurbished unit with rebuilt injectors I put on 2 days ago. I have replaced the secondary ignition coil under the distributor cap as well. Pulled the engine codes I was told by the mechanic that the MAP sensor code is the only one he has found.
Would a shorted out tps sensor pop a fuse? If so which fuse would it be? Any other ideas on whats going on here?
My buddy is working on it tomorrow but I would like to hear any ideas yall have.
