No Spark !!!
opfor2
Ventura County, CA
****UPDATED**** No Spark !!!
Hi All,
I’m having a no run problem with my 1990 Chevy Blazer, 350 automatic w/ throttle body injection. The truck started up for about three seconds and when I put it into drive it died. I checked all of the fuses and they all appear to be ok, there is no code stored in the ECM.
I disconnected the fuel line from the throttle body and turned the key on and guess what, We have a strong stream of fuel so that would eliminate the fuel pump.
After doing some more trouble shooting I determined that I'm not getting a spark so I guess it's the ignition. I.ve heared that the ignition modules are cheap and fail alot on the Blazer is this true ? How do I test the module.
Thanks
Dan...
Re: Fuel delivery problem
just because you had fuel at that moment doesnt mean you do now...id try bleeding it out a couple incase it ingested some air into the lines...will it start if you pour fuel down the TB??
Replace the fuel filter, pull the injectors and check the filters on the injectors...and check Fuel pressure!!!Just because you have fuel volume doesn't mean you have enough fuel pressure.Make sure the ECM's signal is reaching the injectors...Maybe try another FP relay...
I know it may sound stupid but did you check the fuses. I had the same problem with a simple cure!
************REPAIRED********************
It turned out that the ignition Mod was bad. $ 29.00 later and the truck is running better than ever.
Thanks to all those who helped.
Dan..
I've got the same problem with an '83 Century I'm tinkering with. Maybe I'll give that a try! /forums/images/graemlins/thumb.gif
Some quick notes... code 42 is usually triggered with a bad ign. module. Also, AutoZone will test your module for free! ;-)
-Dan
