Hey all,
Brand new here and hoping to pick the brain of you seasoned vets. Just picked up a '74 Jimmy on a steal...$300!! Talked seller down from his modest $1500 asking price when he couldn't get it to start for me. Mind you its got A LOT of rust, but between the salvageable parts and at $300 its more than worth its weight in scrap if I was so inclined. But I would never do that considering its a full-vert, pre-smog (California) classic! Plus its a got a fairly new Softtopper, new radiator, new brakes, new tires and shocks! Anyway...Trailered it home and got to poking around. Found the starter was toast and the two fusible links near the starter were also fried. Replaced those items, made sure the battery had a full charge and got nothing when I turned the key. Tried bypassing ignition switch with a trusty Harbor Freight bump starter and can only get a click from the solenoid and cannot get the motor to crank. Anywhere I check I get 12+ volts. 2 fusible links on the firewall near the junction box are still intact, all fuses are good. Also have no lights or any other signs of life...I'm at a loss now. I pulled the ignition switch last night and will be replacing today (just cause its old and they're cheap). Any other areas I should look??? Any advice is appreciated!
