No Start, No Spark, urgent help please...
K5er4Life
Chillen the most
Yorba Linda, Ca
I am having trouble finding out what exactly is my problem as to why I am not getting any spark. Its a 87 TBI. I am getting power to the power wire on the external coil but am getting nothing out of the coil. I figured the coil was the problem so I replaced it. Now Im starting to think it might be a relay, fuse or something. But I dont know where to start. These damn electrical problems suck. Please help need it urgently as my truck needs to move no later than tomorrow.
check the ignition module, it is under the dist. cap, most auto parts places will test it.
check the modual under the cap and the pickup coil under the cap, theses are the biggest causes for a no spark situation
Thank you, I will run out and try that, but I am a little unclear as to how to go about removing it. I know its under the cap and under the rotor, hell Ill check back in a few minutes once I see what everything looks like under there. Thanks for the help, be back in a few...
Remove cap and rotor, then unplug the two wiring connectors and remove the two screws that hold the module in place. Install new module. Be CERTAIN that you smear the back of the new module with the thermal grease that comes with it,before you install it. Otherwise it will overheat and burn out pretty quickly. :(
If the module doesn't fix it then you need to replace the pick-up coil inside the distributor but you have to remove the distributor and take it completely apart in order to change it.
Thanks guys, I really appreciate it, got it all straightened out. Turned out to be the pickup module. A quick look at the chiltons helped a bit too. Last night I was on my way back home when the truck took a dump on the freeway. Luckily I wasnt far from home and had a new bottle of jack so when I waited for AAA to show up I had some drinking to do.:saweet:
