smalltruckbigcid
Low mileage 6.2 was running good and now won't start. Bled the fuel system, checked trandfer pump pressure, 6.5 psi and holds, swapped the injection pump for a known good one and checked the shutoff solenoid on the new pump. It has 12.8 volts and you can hear it click with the key. The volume from the transfer pump seems a little low, maybe most of a cup of fuel in 10 seconds of cranking. Is that enough? Anyone got any ideas.
George
George
