i get noise when a go into turns on the k5. it has 4x4 dana 44. what could be causing this? on one side i replaced the spindle, hub and wheel bearings. the bearing was spinning on the spindle. the race moved in the hub. Is that common? I thought that would fix it but it still makes noise. maybe the other side is bad also. I did check it and the bearing race did not spin like the other side. this is in 2x4 mode... not sure in 4x4 mode
