2011 rav4 new alternator (installed a week ago) Alterowas going out, no doud about that.
Battery volt at cold is 12.47ish
Battery while running at idle is 14.57 ish
The other day when starting it in the am it was sluggish. Dash lights went down (longer than usual) then it fired up.
When leaving work it started but not a strong start like right after the new alternator was installed.
When the key is turned on I let it go for about 10seconds to get fuel pump going ( thinking this may be the issue) but waiting 10 seconds to fire it up didn't change much.
This morning at cold (4am inAZ) it started fine enough and maybe its me looking to tinker with something..
Could it possibly be the starter? And how would I check it the starter is going out? Car has 150,000 miles.
Battery is about 2-3 years old which is about all you get in AZ, generally.
Rav4 forums werent much help,
