WOTBandit88
Hey guys. Getting conflicting opinions on the use of overdrive and wanted to see what you guys say. I have a 700R4 with a 3:08 ratio in the rear (GHEY) and 31 inch tires. I use drive around town and usually overdrive when i hit over 45 mph.Some guys tell me its fine to use OD even just when cruising around town. When I pull grades and i feel it slow down i let off the gas and drop it into drive till i pull the hill. Is this how its supposed to be used? I don't have a tach so it bugs me not seein my RPM when I pull a hill in drive and the motors wound up a bit. Im used to my camaro just hitting hills at 80 in fifth gear and keeping my foot in it. (and thats with the peepee L03 305). Anyway to get a rough estimate on RPMs by the speed im going with the info I gave you up top? Thanks for any input guys!
