mattman4x4
So I get that changing the stock rear shackles impart lift by increasing the distance between the frame and the springs.
I am confused about the DIY kits, if you only cut off the one rear shackle mount and install a new longer one, but leaving the stock shackle on the same spring on the other end how do you get a lift? Perhaps someone could explain?
